hi guys
i captured a video in my DVB device (Starsat SR-X7300usb)
and i want to make a DVD disk with high quality
but i want to edit the videos coz i want to cut some scenes
like comercials etc..
the files are MPG or TS, let's talk about MPG coz at least the computer reads it directly
when i convert these mp4 files to another format,
the file's frame rate discreases a lot!!! i mean become [not smooth as the input files]
so what can i do
( is projectX a good software ) ?
please guys, i want a software let's you drag DVB/DVR TS & MPG files and cut, join,
convert, merge without losing resolution and without any frame rate problems
thanks...
	Qoute:
 i meant mpg, not mp4
	thanks a lot man! videoredo rocks!!!
 but convertxtodvd i idid't like it cause it aint merge all the files to one dvd
 i want the best DVD burner that merges all the mpg (captured edited files)
 to one file dvd and burn it (without any problems such as frame rate
 problems and "video is later than the sound" problem)
 please reply as fast as u can
	ConvertXtoDVD can 'merge' segments into a single title. Add you first file, then right-click and select 'merge more files to this titleset'. This will opena new screen where you can add and arrange the other files. Read my blog here.
	an alternative to convertxtodvd is dvdflick if u want freeware.... not sure of a freeware alternative to videoredo
  What would you do with this captured video? (Comb-like problem)By Asterra in forum Capturing and VCRReplies: 7Last Post: 6th Sep 2011, 12:13
  screen captured video convrted to mpg dvd - will they be an issueBy perfection in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2009, 04:32
  problem with mpg formatBy volam in forum EditingReplies: 0Last Post: 17th May 2009, 14:31
  captured video vertically squeezed, fix during conversion?By krcoggins in forum Video ConversionReplies: 2Last Post: 16th Feb 2009, 16:32
  Ok, captured my video as AVI formatBy geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 00:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
